Whistle?
Discussion in 'RAM Rebel Problems and Issues' started by Dynamic, Aug 27, 2015.
  1. RAMBLING
    RAMBLING Grasshopper
    Mar 31, 2016
    4
    0
    Minnesota
    Just wondering if the pillar weather strip was the issue ?? I haven't had a chance to try and isolate it yet... As mine as well is whistling at highway speeds...
  2. RAMBLING
    Mar 31, 2016
    4
    0
    Minnesota
    Sorry just saw the post on the antenna I will give that a try.
  3. reveiled
    reveiled Junior Member
    Aug 30, 2015
    113
    43
    Ft Lauderdale, FL
    I just installed back my shorty antenna. Will try it tomorrow to & from work to see if whistle is back.
    I never cared to do it but after seeing your 3 wiper videos, i'm wondering if maybe it was the wipers and dealer did something to them.
  4. bighorn345
    bighorn345 Grasshopper
    Mar 13, 2016
    15
    14
    Cross my fingers but so far so good with mine. No strange noises or whistles. With only 2,200 miles on the odometer, the only thing I noticed so far is the back doors don't close all the way unless I slam them and my center console doesn't close very easy unless I slam it as well.
    • Agree Agree x 1
  5. tcombs
    tcombs Grasshopper
    Feb 11, 2016
    1
    0
    I have a whistle also. Like the window or door isn't closed good but they are.
  6. RAMBLING
    Mar 31, 2016
    4
    0
    Minnesota
    This weekend i hope to have some time to check into this a little deeper .. I will keep you posted as to what I can come up with!!
  7. reveiled
    Aug 30, 2015
    113
    43
    Ft Lauderdale, FL
    Forgot to update on that.
    Unfortunately installing back the shorty antenna brings back the noise.
    I pulled over and remove it immediately.
    Good luck mate!
  8. johnj
    johnj Rebel Guru
    Dec 24, 2015
    1,433
    333
    I wonder if your antenna mount is loose? That chromed ring plate on top of the mount is actually a special threaded unit that tightens to the truck body, holding the little painted mounting housing to the side of the truck. Mine was not snugged up very tightly when I changed my antenna out. I snugged it on more before screwing my antenna into it. I didn't have a spanner wrench to fit it, so I used a strip of rubber from an old bike inner tube. Wrapped that around it to protect the finish, then grabbed it with channel locks and snugged it a little.
  9. RAMBLING
    Mar 31, 2016
    4
    0
    Minnesota
    Had mine in for the whistle as well !! Dealer said the windshield moulding was not installed correctly on that side way home still whistle !! Will call them again in the morning !! Anyone else have this issue resolved ?? It's not the wipers or the antenna I even went as far as using paint friendly masking tape and taped off the windshield and door jamb !! Still whistles!!
  10. mboftexas
    mboftexas Grasshopper
    Aug 4, 2016
    10
    3
    Door Seals?
Share This Page
Search tags for this page
16 rebel whistle noise
2014 ram v6 whistle when starting
2015 ram 1500 a pillar whistle
2015 ram 1500 wind whistle right side
2016 rebel whistle noise from dash with fan off
dodge tsb23-024--11
ram rrt 23-024-11
ram whistle
reseal hvac box ram rebel 1500
whistle ram rebel
