Hi All: no better place to ask them here on a 20” dual row LED light bar in my grill. I think it would look sharp but mounting seems a bit awkward since no real place to mount. Anyone have any mounting suggestions?
Thank you! Love the location and video! The 2019 has a few changes to it for location based on your video but I think I can make it work. The switch location will also be a bit different but have some ideas on it as well. Thanks again! Very much appreciated info.If I had to do over again I would upgrade the light bar. But keep everything else the same. Go brighter!
Sent from my SM-G965U using Tapatalk
How did you mount the light? wiring is not an issue.View attachment 28051
Not the best pic, but I put a 22", triple row, on the high spot at the top of the bumper. Originally, I was going to tuck a wider curved one in the opening above the license plate, but I wanted the light to be higher. This triple row has two focused beams as well as the center floods. Really is amazing for it's small size. I wired to a toggle in the panel next to the steering wheel, but I'm going to change that to a 3way switch so I can use it with the high beams or, by passed for full time on.
Just drilled 2 3/8" holes in the top of the bumper. Sealed them, before I dropped in the bolts, so they won't rust. ( I've forgotten the make of the sealer. A friend owns a body shop and he gave me the stuff.)How did you mount the light? wiring is not an issue.
Thank You!Just drilled 2 3/8" holes in the top of the bumper. Sealed them, before I dropped in the bolts, so they won't rust. ( I've forgotten the make of the sealer. A friend owns a body shop and he gave me the stuff.)
Where did you purchase the light bar everyone is telling me they don’t have one for the 2020 Rebel Sport??
This is what I did! Bought same light bar. I had mine wired so it comes on with high beams, as I live rural and wanted it for spotting deer at night. Also added a switch so I can turn the bar off and use high beams only, but don't really think that was necessary after all. I have 2018, and I don't know whether brackets are the same in 2019's. Hope that helps.
