1 - 2 of 2 Posts
Anyone can help me went offroading, when i hit a puddle i made it and when i went out just barely truck stalled , filters soaked , i know it was dumb but just had to send it . It still runs (power window, ac , radio etc but won’t start . Message i got on dashboard are attached . (Abs ) and (service electronic stability control).
First thing I would check is fuses and relays. The Ram fuse box leaves a bit to be desired with regards to being water tight. It’s simple to check with a multi meter for the relays, and visually for the fuses
Edit: Also while your at it, disconnect the battery for 15-20 minutes. That’ll clear any latched but non active faults giving you erroneous messages or codes. Not saying it’s gonna clear but that’s the first steps I’d take
1 - 2 of 2 Posts
