Where is “around here” where 37’s aren’t legal? Power wagons and raptors come with 35’s from the factory and both will clear 37’s with only minor rubbing stock. I’ve run tires as big as 42’s on the street in California without issues?
that looks awesome. what wheels are you running? 20"s on 35"s? i want to get rid of the air suspension on my truck but i dont want to go too high.
truck is my daily driver ya know? i want to run 18" on 35"s. and i think if i lift it 6" that is too high.
there is a guy that fit 35"s on his rebel by putting it on off-road mode and pulling the fuse out of the air suspension.
i dont want to do that. i know you can fit 35"s on the BDS 4" lift for the air suspension but i want to do the
swap to coil overs and i havent found anything but the 6" coil over kit for what i want. i really dont want to lift my rebel that high tho.
if i can find a 4" coil over kit ill be happy to do that.
Hi, these are 20 on 35s, so this is what my daily driver look likes, for the swap, the 6inch kit is ajustable, its ajusted to 6 inch factory default, but you can set it to 4in on the coil, and buy the 3in rear lift for an overall 4 inch. you would be able to fit 35s
‘16. Didn’t want an 18 or newer. Got a used 16 with only 8k miles so no bypass. Getting duplicate name on network error. Changed name. Changed workgroup name. Reset IP address for network and interface. Have messaged back and forth with alexey. Nothing has worked thus far
So I finally got back into town ordered the coil overs for the truck everything should be here in 3-5 days the guy who runs the shop said hell be taking pictures of the install so for anybody who is interested I will be posting those here once everything is said and done
Hi,
Newbie, first post. Wondering what's involved in removing the air ride suspension?
A bit of research pointed to taking out the air suspension and putting in springs, shocks and read spring Isolators. Also to disconnect the compressor?
Is that all there is to it? Does anything need to be...
I have a 2017 Rebel with air ride. I started noticing some softness in the rear end, especially after driving down some rough road for a while. There are a lot of times where expansion joints and large cracks in the road (I'm in Illinois, so all roads are crap) will cause the back end to jump to...
I'm hoping for some quick input from people whose air suspension has been operating properly.
After going back and forth with the dealer on suspension issues with my 2018 Rebel, they finally got "permission" from Ram Engineering to manually adjust the ride height values for each corner.
My...
A forum community dedicated to Dodge Ram Rebel 1500 owners and enthusiasts. Come join the discussion about performance, modifications, troubleshooting, maintenance, and more!
