1 - 1 of 1 Posts
I have a 2019 Ram Rebel
My serpentine belt just broke and I almost trash my Engine because of it.
The pulley is cheaply design it’s made of plastic and it worn out ,there is 2 pulleys you have to replace at 50k or you will break your engine it will leave you stranded
31710
The pulley on the right is the old one if doesn’t worn out evenly because of that it breaks you’er belt
I will also recommend changing the battery at 50K or it will leave you stranded,
I love this truck regardless of the issues
Good luck I hope that helps
1 - 1 of 1 Posts
