1 - 5 of 5 Posts
After towing my camper for the first time I noticed I didn't have a trailer brake (I know too late to notice that). Has anyone installed the Mopar brake controller?
Should not be too difficult just have to follow instructions. If you are using a MOPAR brand check with the Dealer, they will install it. I'm not sure but if the Dealer installed it then it night be covered under your warranty. Please check that first to make sure.
Big Red
I checked into installing one on mine. I ended up cheating and letting the dealer install it because of timing. It looked fairly simple in the directions that I read. The trick is getting the computer to understand that it's there. The benefit to the dealer doing it (roughly $350) is that now it's in the system with the vin and they have to deal with it, & it's covered under my warranty now also.
Discussion Starter #5
Thank You all for the encouragement... I installed mine on Sunday in about an hour, was pretty easy. Had it flashed at the dealer today for $60
1 - 5 of 5 Posts
