1 - 5 of 5 Posts
Whats out there? I read contradicting things about 2019 lifts fitting 2020's. Who can show me the way? Want a 4+ lift. truck is a supercab
Premium Member
I'm with you Big Mike. I have a 20 Rebel and want to add some mods, but everything I look has some caveat where I can't use it. For instance, I had settled on a 6" Rough Country lift with new coilovers and rear shocks. Then I noticed that it won't fit with the 18" factory wheels. So unless I buy bigger wheels and tires, the lift I wanted is a no-go. I'd be OK with a 4" lift, but at this rate it seems that I may only be able to add a 2" front leveling spacer.
This is my first post (<1,000 miles) on the site, so any help or suggestions are welcome. Thanks!
I would recommend going with the mopar lift kit. It is designed for the truck and won't create issues with your warranty or drivability
1 - 5 of 5 Posts
