Which led lights work nicely for the front grill I was thinking white in color , are they a hard install ??? Thank you
Is fuse 104 under the hood or dash. I have them on a remote but would like them to turn on and off when I start the truck and turn it offFuse F90/91 - - Batt +12v (Constant Power)
Fuse F104 - - Acc +12v (Keyed Power)
I think fuse F104 would be fine to tap off of. Its the power that will only power up after to turn on the ACC
Hhmmm, I don’t have a 104 under the hood fuse blockYeah, it’s under the hood in the main fuse block
Very nice look white on white truck ! Nice install thank you
I tapped into the side amber lights, but ran it through a relay and a fuse line. I followed a YouTube tutorial which was really good from here:
He also details the wiring diagrams etc. The connecting wire on mine was different but I found the correct one with a tester
Ok I’ll look into it , but you mentioned you needed a ready also ?Im not really sure, getting the wiring through the grille and down to the wheel arch wasnt too bad just take the front driver side wheel off and take the inner wing out and its easy to access the wiring loom coming off the back of the drivers side headlight. Trying from above was almost impossible.
I ran it through a relay yes. Basically you run the power directly from the battery to the relay, and you run a wire from the side lights. When the side lights come on it sends a signal to the relay which opens the relay and activates the LEDs this then protects the system from any voltage drop and errors (according to waterfowler video above).Ok I’ll look into it , but you mentioned you needed a ready also ?
Thank you sorry to keep bugging you , would you have a picture of the relay you used or linkI ran it through a relay yes. Basically you run the power directly from the battery to the relay, and you run a wire from the side lights. When the side lights come on it sends a signal to the relay which opens the relay and activates the LEDs this then protects the system from any voltage drop and errors (according to waterfowler video above).
