1 - 20 of 41 Posts
Discussion Starter · #4 ·
Noise is barely noticeable on highway. More noticeable when driving slowly, and turning on pavement. Perfectly smooth and tracks straight also.
I do have the airbag adjustable links and have it raised one setting (aero is now same as normal was, normal is what off road was, off road is higher yet)
Looks great! I'd love to do that...but my garage clearance is already very close!
Discussion Starter · #13 ·
I haven't realigned yet but probably will, just got installed yesterday. I use Aero mode on paved roads to keep as close to stock height-wise. On dirt roads I use Normal and when off roading I use Off Road. Doesn't feel like I necessarily need an allotment but again, I'll probably get it aligned to be safe
Discussion Starter · #20 ·
Land vehicle Tire Vehicle Automotive tire Motor vehicle
Just an update - unfortunately I've noticed some mild rubbing. This occurs from the control arm on the inside upper sidewall area, and happens when lifted above Aero mode. So oddly enough if I lower the truck it clears but when I raise it it rubs.
I can also hear it rub slightly in the rear when off roading where the rear is articulating. I think it'll be fine but the extra width (supposedly 12.6") is a touch too much...... if I was to do it again I'd go with 295/70/17 or maybe 305/70/17's at the most.
1 - 20 of 41 Posts
