1 - 4 of 4 Posts
Can you put in a 5th wheel hitch with the air ride suspension? I’ve been told not to but haven’t talked to my dealer yet.
Buddy of mine did it, no issues.
What is his specs? 5'x7" bed, hemi or diesel? Trailer weight/length?
Very interested as I want to tow a 5th wheel if I can.
I saw somewhere something on RAM Mopar chart you can go 19k pounds on trailer weight.
Not sue if this is true.
I dont think you guys can pull any 5th wheels. Chances are you'll exceed your payload weights, there are a select few 1/2 tons capable of doing so, and a select few 5th wheels able to be done.
Most 5th wheels start at 1400lbs hitch weight.
Average 1/2 ton payload is 1700lbs
Leaving you with ~300lbs to play with, not including you, your passenger(s) and cargo.
Rebels in particular I see payloads are 1000-1500lbs.
1 - 4 of 4 Posts
