I ended up pulling over for a couple pics in Hampton Beach New Hampshire.
Anyway these pics were taken in the suspension mode that I drive it in 99 percent of the time. Normal mode.
On to the pictures....
Bill
20x10 wheels with 35'sI like the stance , what's the diameter of your wheel ?
Did you have to mod anything else to get the 20's and 35's mounted?I like the stance , what's the diameter of your wheel ?
WOW now that looks great!. What are the specs of the 35s? I am looking to get 20s and would like to have a bit wider tire but I am worried about rubbing.View attachment 1575 View attachment 1576 View attachment 1577 View attachment 1578 My wife and I took a nice scenic ride on the coast today.
Bill
I did the link mod, where you switch the rears with the fronts and the fronts to the rear. It tricks your truck into thinking its lower than it is so you get a little more height out of your settings. I run my truck in Normal mode 99 percent of the time. And from my understanding of the link mod that basically is your old offroad height.Did you have to mod anything else to get the 20's and 35's mounted?
The tires are Master Craft MXT'S in a 35x12.5x20.SMRebepost: 11856 said:WOW now that looks great!. What are the specs of the 35s? I am looking to get 20s and would like to have a bit wider tire but I am worried about rubbing.
Good question!when I performed the link mod i received a check air suspension message. so i put them back. before i did the switch i made sure the suspension was locked. how did you manage.
