I have adjustable links on mine and it's awesome I love it. The ride is a tiny bit rougher but it depends on how you want it. Obviously the higher it is the more the ride is impacted. I have mine raised just enough to fit a 35" tire with 20" wheel on it without rubbing.Has anyone lifted their truck with the adjustable suspension links? Does the driving feel worse? How does it look? Send pics
Where did you get yours from?I have adjustable links on mine and it's awesome I love it. The ride is a tiny bit rougher but it depends on how you want it. Obviously the higher it is the more the ride is impacted. I have mine raised just enough to fit a 35" tire with 20" wheel on it without rubbing.
Ehratraxion.comWhere did you get yours from?
I honestly don't remember. But I do remember I made them equal to the stock plastic links if you were to switch the fronts to back and the backs to front and then I made them a 1/4" taller. They come with these instructions if this helps. Remember to get an alignment done you will need it.What measurements did you use on your adjustable links, I pick up my Rebel Saturday a ordered the links today.
Sent from my SM-N920V using Tapatalk
Oh and you'll know when you go too high with them. Just do a little at a time and take it around the block until your satisfied with it. You'll know your limit when you start bouncing all over the place lolI honestly don't remember. But I do remember I made them equal to the stock plastic links if you were to switch the fronts to back and the backs to front and then I made them a 1/4" taller. They come with these instructions if this helps. Remember to get an alignment done you will need it.
I'm pretty sure but done quote me on it. It's been about a year so I can't tell you for sure. But I do know that i started them off with the front being the same size as the stock backs and the backs being the same size as the stock fronts. I then adjusted them then drove and tested then adjusted again until I was satisfied with the ride to the point where I wasn't bouncing all over he place. The higher you go the bouncier it gets.1/4 inch more than a stock on each link?
