1 - 2 of 2 Posts
I have a 2018 Rebel and about 3-4 months ago I took the fuse out that changes the ride height and kept it in off road mode. I did this because I was getting 34’s on the truck and wanted a little extra wiggle room. I’ve noticed over the past few days that the front end is sloping down like the air ride is losing some air. Any ideas on how to fix this? Can I take it to a place and have them re-air up the air ride? Im new to air ride and would like some input. Thanks y’all
I'm guessing that you have a leak in one of your front bags. Need to get that checked quickly as the compressor will overheat ($$) as it keeps trying to add air. The airbags are around $400 each, with labor around $200 or DIY. I would replace both fronts at the same time.
1 - 2 of 2 Posts
