1 - 12 of 12 Posts
For everyone that has had “challenges” with your FCA dealership or with FCA “Customer Service” related to failing air suspensions on your RAM Rebel or other Dodge/RAM 1500 series, here’s my story and my solutions (because neither your dealership nor FCA is going to help you). Dealership tells me the air suspension is the same in the 5th generation 1500's so this may be relevant to anyone with a 2019 or contemplating a 2019.
By way of a bit of context, I have a 2016 RAM Rebel, with 62,000 km’s. I absolutely love the truck and had no issues with it. I live in the interior of British Columbia where temperatures are generally moderate in the winter but routinely drop below zero between late November and the end of February. This winter was particularly cold with a major cold snap in February that routinely saw temperatures drop well below -10.
The first time my air suspension failed was in January 2018. Temperatures were below zero. The vehicle was under warranty and the dealership replaced the compressor, no questions asked. This fix would have cost me about $2600 if it had not been warranted. No problems from the time of repair until about a year later.
In December 2018, the air suspension began to act up again but after the vehicle warmed up, it would reset itself. This occurred through January with the vehicle dropping down all the way in the front overnight but resetting itself after warming up. The vehicle was still under warranty and I talked to the service manager and I suggested (and he agreed) that I monitor the situation. At that time he told me that he was getting a lot of complaints related to this issue. In early March, the system failed again permanently.
When I took the vehicle to the dealership, there were 3 other vehicles in for service for the same reason (and there was a brand new 2019 on the lot that had failed). The service desk guy bemoaned the fact that FCA was doing nothing to assist dealerships or customers with failing air suspensions and gave me the customer service # to call. He also told me that a guy with a 2017 Rebel was in for the same reasons, his truck had 67K on it and was past warranty, and he didn’t have the cash to replace the compressor so they were contemplating switching out the suspension (ironically, the guy traded his vehicle in instead and the dealership put it up for sale for $42k even though the suspension routinely failed…you’d think they would have at least sent it to auction. The truck was a very distinct dark grey Rebel with burgundy trim pieces and I happened to see it on autotrader a few days after I had my own truck in. I have to say that really made me angry).
As for my options, the dealership put the truck on the hoist and gave me two choices – the more expensive option was $668 (see invoice attached) and he told me there would be no guarantee that it was a long term fix but it was a better solution than the cheaper option (which he estimated at about $400). I opted for the more expensive option and tried to negotiate a goodwill or reduced rate. Dealership said they couldn’t help me – they were stuck between a rock and a hard place. FCA was completely useless saying the truck was off warranty, there was no issue with the design, etc. Part of their response follows:
“I have been in contact with the service department at XXXXXXXXX Chrysler and was advised of the evaluation of your vehicle. There was no replacement part required to repair your vehicle; therefore FCA Canada is unable to review for any outside of warranty assistance. We must stress that they are qualified to assess vehicle conditions which are causing concern, and advise regarding the possibility of warranty coverage to any required repair. As such, we must concur with the information they have provided pertaining to your vehicle repairs.”
Typical runaround. I would be more than happy to share my correspondence with anyone on the forum that wants it – just to save you time or perhaps to compare notes. I would however recommend that you still contact FCA via their online forum to lodge complaint – just don’t expect a remedy.
11 days later, the suspension failed again. Dealership put it back on the hoist and said they could repeat the same “fix” but once again no guarantee on the results and no goodwill discount. Because the parts weren’t failing, there wasn’t even any relief on the cost since it was entirely labour related. The dealership was “kind enough” to encourage me to buy a new vehicle and they would discount any new purchase by the cost of my previous service $668).
Instead of giving FCA anymore of my money, I researched my options to replace the air suspension with a conventional set-up. See the build-sheet for what I eventually settled on through Sportsman 4x4 in Kamloops, BC. This was a $2300 job and quite honestly, the truck rides even better than before.
In the meantime, I emailed a class-action legal firm in Canada who had successfully won a case against FCA previously. While sympathetic, the lawyer had this to say:
“In my opinion, a class action will not be successful because the recall does not involve the safety of the vehicle. Your facts involve comfort not safety. A recall about safety, for example, involving air bags will be the basis of a successful class action.”
While I think it could be argued that a failing air suspension is a safety issue, because from my research the suspension doesn’t fail while the vehicle is in motion, the lawyer is likely correct. It strikes me if the system were failing while the vehicle was in motion, there may be a case to be made that it is, in fact, a safety concern. So basically, the dealerships and FCA have us collectively by the balls. If you have an air suspension system (which we all wanted for the benefits, features, convenience, etc.) and you live somewhere that the temperatures routinely fall below zero, you won’t get any relief from either the dealership or FCA (or even from the legal system).
My take home messages:
• If you live in a cold climate, don’t buy a 1500 with an air suspension system.
• Solve the problem yourself. $2300 for a brand-new suspension set-up that is guaranteed for 1 year/20kms is cheaper and more convenient than multiple returns to the dealership to do work that doesn’t solve your problem.
• Dealerships don’t care about your loyalty. I’ve bought 3 vehicles from the same dealership over the past 3 years and have routinely serviced them there. I’m tempted to name the dealership but there’s really no point – at the end of the day, I firmly believe that all automakers and dealerships are cut from the same cloth. That said, I won’t be giving that dealership any more of my business and this is the last FCA vehicle I will ever buy.
• There are no such things as ethics when it comes to dealerships/automakers. When the same dealership can resell (and profit from) a vehicle with known and unfixable problems at a premium price, after likely low-balling the previous owner on a trade-in value, what other conclusions can one draw as a consumer?
• Goodwill – there’s no such thing from either the dealership of FCA
• FCA Customer Service is a misnomer….there is no service, only excuses
• Best of luck to all of you. Happy to engage more if it helps you.
Yeah couldn't agree more with your ending statements ended up removing the air ride last year I think it was late November and thankfully I did it when I did because we had one hell of a cold spell here in manitoba it was minus bloody 30 for almost a month and a half it was brutal man but I was the only rebel on the road for most of the winter and I actually had a vehicle to drive unlike the year prior to that
If you don't mind me asking how much did it cost to remove air ride?
I'm having issues with my 2016
I live in Winnipeg, Manitoba, Canada and I just bought a used 2017 Ram Rebel and I had the air suspension pre-emptively swapped out this week by a local Ram dealership. They used a Monroe suspension for the conversion.
Apparently they have done this before for others that buy trucks with air suspension in colder climates. It cost me approx. $2700 before tax for the parts, labour and 4 wheel alignment.
The car sits at the previous "normal" ride height now and actually rides way smoother than before. I decided to do the change in advance of any problems before it got too cold. Having said that, I had already had one air suspension error where it told me the system was cooling down and wouldn't change ride height before I had made the swap.
Now that it's changed, I can enjoy the truck!
-RP
Hi there.
Did you remove the suspension yourself or have someone do it? Where I live it's about $5,000 to remove. Can I ask what you paid to remove it?
Hi there.
Hi Ssimm, $5000 is way too much. As you can see from my previous post, everything was done all-in for $2700 Canadian dollars before tax with the Monroe suspension kit. Any Ram dealership should be able to do this for you.
-RP
hello great summary. I live in Quesnel and have had my 2017 rebel for two years. I tow a trailer for most of the year as it is my side husiness, it weighs 7000lbs and need the ability to tow no matter what, my question for you is: was your towing capacity the same once you installed the new suspension?
Hi there,
I wish I read this forum before I went out and bought my 2016 limited. I’m having trouble with this thing in 30-40 degree weather. I took it in once and they replaced the compressor and interior switchboard under warranty. I’m planning on taking it back because it’s still not 100 percent.
But I have a few questions regarding the class action portion of your literature.
if you win the class action than Chrysler (or RAM) would have to do a factory recall and fix every truck equipped with air bag suspension correct?
With that being on the table, Chrysler did a factory recall on my 09’ 1500 replacing the pinion nut in the diff case.
was that via class action lawsuit?
If so how does a pinion nut in your differential create a potential safety issue?
I mean it could totally cause a mechanical failure but my truck was damn near 200k at that point.
-RP
Hey. I have 2017 ram limited. Tired of air suspension fail. Can you give me more information about conversion kit. I live in Winnipeg as well. [email protected]
Hi there, not much more to say other than what I already posted. Totally worth doing. Give Murray Jeep Ram a call in Winnipeg. They will do the work for you. I did the conversion during COVID in 2020, so prices may have gone up since then. Ask for Leon Goren in service, he was the service advisor I spoke with and is a great guy to deal with. His number is 204-284-6650, extension 2210 and his email is Leon Goren [email protected]. It's a conversion from air suspension to a Monroe suspension. When you speak to him he'll know exactly what you're asking for.
-RP
1 - 12 of 12 Posts
