No. My kids live in Alberta, Canada and every year in the winter the suspension fails. It becomes unusable, and the dealership has fixed it numerous times and still refuses to acknowledge that there's a problem with these trucks.
And it costs thousands of dollars to have it removed. Does anyone have any ideas?
Well. This whole thread is based on solutions to the air suspension problem. In summary you can:
1. Keep the factory air suspension, continue to pay for repairs and try to fight FCC or FCA. Good luck. FCC/FCA has no interest in resolving the issue. Apparently they have "solved" the problem on 2020-2021 models by replacing defective air bags. My issue wasn't the air bags. It was the compressor and associated valves. I can say that as, on one collapse, I was able to put the truck in a heated garage for 10 hours and return it to normal height. I selected off road, then pulled the fuses for the compressor and ride height sensors. The truck never lost height. If the bags were the issue, they would have leaked. The issue with this solution is, in off road height the truck rides rough and is bouncy. Also, if you go this route, get the truck's alignment done.
2. Remove the factory air, and install after market air. Big money solution.
3. Remove the factory air and instal the rancho conventional coil suspension solution provided by members on the forum. This what I did following the parts list provided "Vshni". I did the work myself and it was approximately 1500 dollars CDN, plus the cost of realignment. This places the ride height at 39", centre of wheel well arc, on each corner. This will level the truck and remove factory rake.
4. Fix the air suspension and sell the truck. I m not trying to be a wise guy here. The issue is, the MOPAR air suspension system does not like cold weather (northern US, Canadian Cold). The first winter, I was fine. The second winter I was mostly fine. Although I found the rear driver's corner always seemed to be a touch lower, but, it other wise adjusted. The third winter, I had three collapses within 2 months. Still under warranty however, we afford these trucks because we work, and running the truck to the dealership constantly is ridiculous. After the third collapse, I sat the height, pulled the fuses and then that summer, removed the air suspension.
I hope this helps.
