1 - 2 of 2 Posts
Hi guys! I have a 2016 rebel and I bought a bullet antenna for the truck. The original antenna will not budge on unscrewing. I’ve used the 8mm and Vice grips and it will not budge. What else can I do?
Not to sound like a jerk, but try harder. If all else fails, grind off at the bottom and drill it our. Most "bullet" antenna hardware come with multiple sized fittings (to fit on a wide range of models) so it will be easy to secure your new antenna. My bullet antenna also come with epoxy to discourage theft. So you should be good with the install.
1 - 2 of 2 Posts
