What do you think about Spray bedliners?
Did you get a liner for your truck?Line-X. There are usually 3 trim lines; basic ~525.00 premium (basic plus ~125.00) and color matching (Line-X gets the color codes from vehicle manufacturers to match your paint code with the line-x spray itself) usually about $730.00 for the color match. ALL trim lines are lifetime warranty (and that's the LIFE of the truck, not some random number the line-x is good for)
LINE-X Sprayon Bedliners, Protective Coatings, Truck Bed Coating, Floor Coating, Industrial Flooring
on my 14 i had bed rug, this one came with spray in, if i could get bed rug to attach to spray in then i would get bed rug again. they are nice, padded too for when you need to get in the bed.Did you get a liner for your truck?
Not yet on the Rebel, but I did with my 2011 Ram 1500 Big Horn (zero issues with it). Still saving a little to do it in my Rebel. "adulting" is hard. Don't have the made money laying around that I used to.Did you get a liner for your truck?
Hey Joe, I've got the spray in and I put a bed rug in it, I didn't attach it and it doesn't move at all, so as long as you've got a tonneau cover it stays put nicely.on my 14 i had bed rug, this one came with spray in, if i could get bed rug to attach to spray in then i would get bed rug again. they are nice, padded too for when you need to get in the bed.
side note, QC i do not need any of your advice. thank you.
Did you buy yours off the lot?I thought they all came with the bed sprayed OEM? That just shows what I know. Mine came sprayed already.
It's a factory option. I bought mine from a lot, but I reviewed everything before I bought it, and it had the factory spray on the build sheet. The dealer had ordered one that way to set out on the lot.I thought they all came with the bed sprayed OEM? That just shows what I know. Mine came sprayed already.
