I installed the factory unit on my previous Ram 1500 and it is not that bad of an install. There is a YouTube out there that is very good following every step. You will save a lot of money installing it yourself. My Rebel came with the very same unit. By the way, if you have the towing package, you already have the wiring harness and you just plug it in. The dealer then will flash your ECU to accept the unit and you are good to go.I want the same thing. Dealer told me if they install it, it will be under warranty with the rest of the truck. Not sure if it will be like a factory install or not. RV Center says they can do it, but I'm not sure how location on dash will be.
What did dealer charge to program?
