Bumper Alignment Fixed at Dealer
15158 Views 26 Replies 19 Participants Last post by  VA10
I think they call it OCD, I had to get the front bumper straight. Got it done today at the dealer's body shop under warranty.
I know there was one other guy on this site that got his done. Looking at the truck; the left side had a 2 inch gap compared to almost a flush driver side
Anyone else getting it looked at?
WTF DC...Most likely built on a Monday...found an inspection sheet in the glove box dated on a Monday (my head hurts on Mondays ever since I turned 30. that was 20 years ago) .....my luck
Reactions: 1
1 - 20 of 27 Posts
do you know what they did to fix it? i want mine fixed but don't want to take it to dealer. i wonder if i can loosen it and push it up
Any pictures of before? What to look for. Mine looks ok
under the headlight is a gap to the bumper ...passenger side was off
They did mention it had a adjustment up and down but not back and forth; it was close enough that I couldn't tell on the back and forth
I should of took some photos; once someone on this site pointed it out I kept looking at it (very noticeable)
The back bumper is off by a 1/10 of an inch too. I had the dealership fix both the front and back bumper. I think all the Rebels have a bumper misalignment, because I looked at 5 others on the lot and they were all the same.
There is no way to do it yourself, its the bracket that needs to be bent. One guy did push his bumper against a tree to fix it though.
Reactions: 1
Do you know what bracket needs to be bent to improve the alignment on the bumper?
I'm not exactly sure what the body shop did, but it only took a couple of hours. I'll take a look under the bumper next chance I get, and try to figure out what they did exactly.
I wish someone had a before and after pic so I can see if mine is good or bad
It is really easy to tell if its crooked all you have to do is stick your fingers between the bumper and the head light on the passenger side. For my mine I could stick my fingers half way through on the passenger side, and not at all on the driver side.
It simply just has to look the same and have an even gap all the way around
Mine was low on the passager side.. dealer fixed it In a few hours..
The bumper spacing was one of the first things I checked. Mine came mounted correctly.
I guess I am OCD as well mine sticks out further on the passenger side than the drivers and also has about 3x the gap under the headlight that the passenger side, mine is going in next week for this, the axle recall, and also my passenger side ram box will not open, you can feel the key turning the lock mech on the inside but when you press the know it doesnt unlatch. I wish they were as simple as the ones on my traded in 2012 2500hd where, three years with no problems this truck cost just as much, oh ram........
Same. Maybe just came out a little wonky on certain production runs
Monday and Friday trucks?:confused:
My front bumper is crooked as well, have an appointment at the dealership tomorrow to have it looked at
See less See more
1 - 20 of 27 Posts
