1 - 12 of 12 Posts
Very very nice. I want to do this.... I've done it long ago on a old ford but that was kinda easy. Tell me more. How long? Was it hard? And where did you pick up the light? Part number?
they are from Recon, took about 4 hour to install. Visor, roof liner, center counsel, a pillars post all had to be removed. Wiring was tricky because these are for a 2500- 3500 Ram which have the proper plugins. I hooked mine to the day time driver( amber turn signals ) if not they will stay on at all times. They do come with a roof pattern also had to get stainless screws longer then the ones that come in the kit. Use a bit of silicone also to seal the lights.
Land vehicle Vehicle Car Windshield Hood
I got the set from mopar and changed the standard Amber bulbs with LED daylight 6000k ones.
The lights were installed by a friend, then I swapped out the bulbs. Total time one hour.
Mine were done for cheaper, $280 parts, $100 labour.
1 - 12 of 12 Posts
