1 - 18 of 18 Posts
Just bought a new '16 Rebel. Traded in my Jeep . I don't make many good moves, but this was one! Anywho, the Rebel has the Remote Keyless Entry. Does anyone know how to disarm the seatbelt alarm? I can find out how to using a key, but as I don't have one of them I'm at a loss. Still trying to figure out how to leave accessories on without a key. For an old man, all the new bells and whistles and related instructions remind me of the confusion involved in the first time I had sex. I know I should always wear a seatbelt but when the kids found out I had a rather large life insurance policy they said they're not really all that necessary.
Easy enough to do it.
With your seatbelt on:
Without pressing the brake, press the start button twice to put it into 'run'.
unbuckle and rebuckle 3 times.. it should chime once indicating that it's disabled.
to re-enable, repeat the process.
the important thing is to not press the brake when pressing start so you can go into ACC and then RUN without starting the engine...
G
Will this work without the push button start?
Who has the Push Button start and is it worth spending the money on?
I have the push button start and tried the procedure about 10 times and still won't disarm.
Turned if off on mine.
Seatbelt on.
press button once (ACC)
press button again (RUN)
wait for the seatbelt indicator to go out..
Disconnect and reconnect the seatbelt 3 times.
press button again (Off)
it will chime once telling you that it was disabled.
G
Seatbelt on.
What year is your Ram Rebel?
Someone else try it and see if it works.
Discussion Starter · #12 ·
First instruction didn't mention "wait for warning light to go out". Tried it after waiting for light to go out but still didn't work. By any chance Nightshade isn't an assumed name being used my x-wife screwing with me?
0% chance of that dude.
Don't know what to say though.. it does work.. there are even some youtube videos on how to turn it off.
Jeep:
RAM:
Charger:
This has not changed in years. :)
I want it off for when the vehicle is in the run poistio. with the door open...in my 09 I found the chime box but can't deal to find where the chirp comes from I see the dash on this truck
Worked fine on my 2016. Dash light is on but no chime. Even when I open the door.
Sealtbelt is off but still a door chime
1 - 18 of 18 Posts
