1 - 1 of 1 Posts
Interior map lights
Hope this helps , if you what to replace the map light for LED lights be careful because the custruction of the light socket is week ad you will break the terminals befor you install the light , you need to take the entire light apart to do this properly , use a screwdriver to pop the lights off from the back
I got my lots at Alla
Par number
1 - 1 of 1 Posts
