1 - 5 of 5 Posts
has anyone looked into installing a led pod (3x3) next to the factory fog lights? I was thinking about cutting out the plastic and mounting a pod there. I will have to pull down the inner fender to take a look at the back of the bumper to see if there is a good way to mount the pod.
Banned
Sounds like a cool idea, do you have an LED light that you would like to use?
Banned
I was thinking these pods View attachment 1773
Well first you have to determine what is behind that part of the vehicle and see what there might be for room and arears to mount too, , to bad you couldn't use the actual light face to clamp thru the cut out opening, it would be easier to mount if it had a flange around the light face and all you had to do was mount screw nuts on the fasteners from behind.
1 - 5 of 5 Posts
