I got my first oil change at the dealership I bought the RAM at a little over a month ago at 4700 miles. I'm now at 9300 miles and today I noticed the car leaking oil pretty bad. I crawled underneath and noticed it was coming from the passenger front side of the engine area.
Luckily, putting it in OFF ROAD mode makes it easy to get under the engine and inspect things. I found the oil filter is directly above the components that were drenched in oil and dripping to the ground. I put some grippy gloves on and was able to hand tighten the oil filter about a full turn.
Now, I'm assuming the oil leak was caused by this loose oil filter so I think I'm in the clear. But the weird thing is it started doing this today, more than 4500 miles after the oil change. Heat/Cool cycles can loosen things but I have to assume the tech that did the oil change didn't tighten the filter enough and it finally worked its way loose enough that oil started leaking......
Anyone else have anything like this happen? Same thing happened to my 2009 Pontiac G8 GT about 4 years ago after the only dealership oil change it ever had. I do all my oil changes now, but thought I would have the dealership do the RAM since its brand new but perhaps I'll be doing my own oil changes on this rig from now on too....
