1 - 12 of 12 Posts
Hi how are you i have the same issue on my 2020 ram rebel im fighting chrysler and i have my lawyers let me know how many miles do you have in your truck plus they play with the tcm and dtcm on the transmission and my rebel its super slow if you have less than 36000 miles call chrysler so they can replaced after 36000 miles its going to be really hard they dont care about the customer
2020 rebel 4x4
Thanks I also have issue with transmission. I have hard engaging and and down shifting. I have a appointment with dealer.. going see what they going to do and front suspension. Thanks
That’s normal, not damage. It’s designed to do that. The saddle on the spindle stops oversteer by bumping against the ridge on the lower control arm, this is on a ‘16 with 38k, a air ride delete and fox coilovers. I’ve got over $30k in upgrades on a $53k truck so believe me, if it were a problem I’d have raised hell about it, but I’m not worried one bit
31818
31819
2020 rebel 4x4
Discussion Starter · #11 ·
That’s normal, not damage. It’s designed to do that. The saddle on the spindle stops oversteer by bumping against the ridge on the lower control arm, this is on a ‘16 with 38k, a air ride delete and fox coilovers. I’ve got over $30k in upgrades on a $53k truck so believe me, if it were a problem I’d have raised hell about it, but I’m not worried one bit View attachment 31818 View attachment 31819
Thanks . Now That I know is normal , Im going go ahead install my level kit !
1 - 12 of 12 Posts
