I think if you reread my posts above, you will see that I specifically did say that you have to do it every time you put it in Drive. Not every time you start the truck.Ok, tried this and the dash never shows that it goes to 8. The only way is to hit the - button, then run it up to 8. However after doing this I can still tell the MDS is functioning. I also assume any time you put it in reverse, park, neutral, etc. you have to redo this procedure... It doesn't seem to be as you guys described. Wonder if this function has been removed, or is now prevented from happening.
