1 - 10 of 10 Posts
After filling the truck with gas i noticed the brightness on the nav screen was barely visible, is there an actual method to adjust it or is it kaput?
Discussion Starter · #4 ·
From time to time my screen goes completely black.. thw dealer says i need an update and it will take nearly 3hrs.. possibly a new unit also.
I actually thought the screen was blacked out and that I had inadvertently passed the screen off button, but, nope, literally within 10 mins of posting the unit worked again, I'm hoping that this is an isolated incident
Too weird! This happened to me for the first time yesterday, I could barely read the screen because it was so dark. I adjusted the dimmer switch below the headlight switch but it was already at its maximum. I ignored it and the next time I started the truck (was running short errands), it was back to normal.
Discussion Starter · #9 ·
Yep, mine was the same, when adjusting the illumination switch when the screen was dark it made no difference, it just started to work again
Reactions: BCT
1 - 10 of 10 Posts
