1 - 11 of 11 Posts
Panduit mounted
Painted and clear coated to match the truck
Distribution Terminal Block Mounted
Finally received the two fuse Bus blocks
Made labels for all the busses and terminal blocks
Made all my wire labels
Went to the store today and bought all the heat shrink and disconnects
On a side bonus also got to give my kids the birds and bees talk after they ask why the disconnects are labeled male and female
Discussion Starter · #2 ·
First set of lights mounted
First 4 of 8 switches
Mounted switch panel in the head liner, but there’s going to another 2 two switches.....
Now I just need to get a fish to fish the wire through the headliner and down to the back of the rear seats
Discussion Starter · #4 · (Edited)
To make the back of the cab more accessible and allow mounting the back pan to the floor behind the rear seats.
I modified the top of the rear seat to fold down
I have to say thanks to Ramrebel.org and it’s search feature LOL
I can’t remember who posted it, but there is a thread all about how to do it
Reactions: zim
Nicely done bunch of extra space back there and if you decide to put seat covers on the back seats itll make your life 10 times easier
Discussion Starter · #6 · (Edited)
Sorry I haven’t updated in a while
I had some delays in the project
I’ve been waiting on Fuse Taps and putting together the main wire harness, plus working on the overhead switch harness...
These are the jumpers for the overhead switches. I had to redo the white wire jumpers because I learned the switches required 2 grounds or negative connections
You should see all the wires I have spread out in my garage LOL
Oh and I bought a DRL light set that have the turn signal functionality....
So, more wire are being added to the main wire harness
Now I just need to figure out where they will mount up
Reactions: zim
Discussion Starter · #7 · (Edited)
Ran the front harness and connected all the lights to the harness
Connected the harness to the fuse taps and the ground to the main ground stud
Ran the harness in through the back of the cab
Also mounted the new DRL/signals
Sadly I’m still waiting on the last fuse taps to complete the signal function.
So I’m waiting to mount the back pan in the cab
I guess this would be Phase 2
Phase 3 will be the fun part.... Running the wires through the headliner and down the back pillars and making room for 2 more switches in the headliner.... then final termination of all connections on the back pan
Discussion Starter · #8 ·
My camping trip was delayed by a day
So I decided to go ahead and finish the rest of this project
I started with pulling the interior panels loose so I had access to the headliner
FYI...after pulling the panel loose there is a Phillips screw holding the top of the panel in place
Then I had to also pull the middle pillar loose... this is held in by two 8mm bolts... or they may be 10mm
Once the panels were loose, I was able to partially pull the head liner down. I then fished the wire for the switches through their mounting holes to the back
Terminated the wires on the switches
And then landed them on their bus blocks
Cleaned everything up and placed all the covers back on
Switches all mounted and tested
Ran into a few issues with the connectors that came with the DRL pods, but after I replaced them with my own... all the lights worked
Now I just have to wait for it to get darker and I’ll get som pics of the switches illuminated and the lights on
Discussion Starter · #9 ·
Nothing on...
Driving Lights...
Driving Lights and Bumper Lights...
Headlights/fog lights, driving lights, bumper lights.
Switches illuminated
Reactions: xsegura
Baron, nice work. I'm curious so gotta ask....... Electrician? Not too many people know what Panduit is or the term blocks....... Very clean and done professionally. I like when some 1 takes pride in their work and goes that extra step to make it look nice in top of it all!
Discussion Starter · #11 ·
Thanks man I appreciate it
Early in my career I started in my companies panel shop building electrical panels and what not. I got great experience mounting din rail, terminal blocks, circuit breakers, and the like. Plus growing up I always loved playing with electrical type stuff and re-wiring almost anything.
Using LED’s sure makes running wire easy... a lot easier than Halogen lights.
My last truck I did a lot of it wrong and almost had a few electrical fires. I made a promise to my wife that I wouldn’t fry this Truck LOL
Everything now has proper fusing, proper gauged wire, and sort of easy to access for any kind of maintenance while staying hidden
I have been thinking of raising the back pan a little higher though because even with the seat back folded down, all the fuse blocks and terminals are down even with the lower portion of the seat
1 - 11 of 11 Posts
