Here we can keep a running list of OWN part #s and questions. Here is a starter list provided by a fellow member. If you have items you'd like added or see something that needs correction please message me and I will be happy to work to make this list useable to all. This is just in the beginning stages so formatting, category changes to come as well.
2015/16 Rebel stock wheel and tire data
stock wheel:
size: 17" x 8"
offset: +18.05mm
bolt pattern: 5x5.5" / 5x139.7mm
weight: 29 lbs.
stock tire:
model: Toyo Open Country A/T
height: 33"
width of tread:
weight: 56 lbs.
total package weight (rims and tires): 85 lbs.
recommended tire pressures, without load:
front: 55 psi
rear: 45 psi
recommended tire pressures, with load:
front: 55 psi
rear: 50 psi
Projector headlight units: (most Rebels have these)
low beam: 9005SI+ **
high beam: 9005LL **
turn signal: custom LED board
Quad headlight units: (some Rebels may have these)
low beam: H11 (1350 lumens) **
high beam: 9005 (1700 lumens) **
turn signal: 3157NA (amber) (300 lumens)
Other exterior bulbs:
Fog: 9145 (1000 lumens) **
Cargo: 921 (300 lumens)
Backup: 7440 / W21W (450 lumens)
Interior Bulbs:
Overhead Console: TS 212-9
Dome: 7679
License Plate: 194
** Note: the headlight and foglight bulbs supplied by Ram are suffixed "LL" for Long Life. The HIR2 is an HIR2LL. This has no effect on the bulb size or socket, it's strictly a bulb engineered to last longer.
stock wheel:
size: 17" x 8"
offset: +18.05mm
weight: 29 lbs.
stock tire:
height: 33"
width of tread:
weight: 56 lbs.
front: 55 psi
rear: 45 psi
front: 55 psi
rear: 50 psi
Interior Bulbs:
Dome: 7679
License Plate: 194
