Off road mode
53413 Views 67 Replies 20 Participants Last post by  Bglee65
Anyone come up with any mods to lock in off road mode over 25mph? Off road mode is so useless in this truck, who goes off roading under 25mph
Reactions: 1
61 - 68 of 68 Posts
it's true. but you can turn aero mode off through your radio
@mmitch5246 what are you dis agreeing
Just another guy that doesn't know his truck, I guess. Trophies don't mean everything. The feature to disable Aero is right there, and in the manuals. I wouldn't sweat it, Joe.
Reactions: 1
If that's the case, it's easy to fix. In this forum, anyway.
Not sure if it was mentioned already but i saw a YouTube post where the guy placed his truck on off road mode once fully lifted he went to the fuse box located under the hood and pulled out the compressor fuse. F50. That left the truck on off road mode.
Reactions: 1
Can you switch from aero to normal mode while driving? is it true once the truck breaks 62 mph it goes down to aero mode?
If you run tow haul it stays in normal
Bad milage is the price you pay for 3.92 gearing. More torque, more gas.
I noticed how the TRX uses 3.21 gearing, apparently with 700hp gearing becomes irrelevant. 😂
Start truck run up to off road, shut off truck pop hood open fuse box and pull fuse to suspension control, close up, climb in start her up and go. Will flash warning to service air ride suspension but stays up till you replace the fuse.
61 - 68 of 68 Posts
