Well if you are really into it, I suggest you go for the LED kit as they would perform better compared with HID. Just not sure what would the output once installed in a projector headlamp.i've been considering using HID's my self but not sure if i should go with LED's instead? any input from anyone?
Thanks for sharing this. I had just changed out my bulbs in my 09 and it made a huge change so was thinking of doing the same on my rebel.I swapped in a set of PIAA bulbs in mine. 9005s fit the highs same as factory and if you get a 9006 you can trim one of the tabs just a little bit with a grinder or sharp knife and it will fit perfect where the 9012 low beam is. The light output is awesome after I did this, hardly even need my high beams and with a 20" light bar in the bumper just in case it makes night driving-deer dodging a breeze
Do you have a pic on what exactly is trimmed off the 9006 bulbs to make them fit? I got a set of 9006's and don't wanna cut to much off and ruin them.I swapped in a set of PIAA bulbs in mine. 9005s fit the highs same as factory and if you get a 9006 you can trim one of the tabs just a little bit with a grinder or sharp knife and it will fit perfect where the 9012 low beam is. The light output is awesome after I did this, hardly even need my high beams and with a 20" light bar in the bumper just in case it makes night driving-deer dodging a breeze
