Just another angle of my Rebel with the BDS lift kit.
thanks for the good write up.No problems. Keep in mind I had to take my Rebel into the dealership after the install due to a fitting and a bag failing which caused some nitrogen to be lost. My installer blames the fitting failing for the issue. My dealer was difficult to deal with because of the lift kit being installed and the vehicle not being stock any more. After finally convincing them to recharge the air suspension pressure they informed me that the sensors were all off causing the system to go into lock mode. In order to fix the problem the tech had to recalibrate all 4 sensors to accommodate for the lift kit. It took approximately 4 hours to complete and $125 for the labor. BDS told me that what I went through wasn't the norm and that their kit will work without problems as long as there are no issues during the install. So, you may or may not need to go to the dealer after installing the kit. It just depends on what happens during the install. They also assured me that their fittIng was more than strong enough to handle the pressure in the line. I guess I just got a defected fitting. Hopefully this is the case because I do not want to have to go through the hassle and cost again.
