Is it just me or do the reverse lights do practically nothing for you when backing at night? There has to be a better way.
Yes, the backup lights are 7440 (or W21W) bulbs that put out about 400-450 lumens. Equal to a moderately bright flashlight, but when you spread that same amount of light out as a flood, it's not so bright. You can replace the bulbs with LEDs of 1000 lumens or more. Chris's mod works well if you have a shell. Some guys make cutouts in their rear bumper for LED arrays, and you could do that if you wanted a lot more light.Is it just me or do the reverse lights do practically nothing for you when backing at night? There has to be a better way.
Anyone get any codes?!I'll be adding a set of SRQ surface mounted lights this weekend since no matter what bulbs you put in the tail lights its never enough.
You don't get codes from Rigid SRQ back up lights since they're their own system and only pull power off to click the relay on and off.Anyone get any codes?!
"Codes" meaning the led lights that people are using in their tail lights.You don't get codes from Rigid SRQ back up lights since they're their own system and only pull power off to click the relay on and off.
you get error codes with those? They are about half the price of the diode dynamicsThese are the LED ones I put in my reverse lights:
Amazon.com: JDM ASTAR 1200 Lumens Extremely Bright 144-EX Chipsets 7440 7441 7443 7444 992 LED Bulbs with Projector , Xenon White: Automotive
