1 - 5 of 5 Posts
When adjusting the seat "up" it only lifts the front shoving my knees up, but does not move my ass up. Is this an engineering issue or a real malfunction?
Make sure you are not toggling the switch. Pull up on it from the center of the switch and both the front and rear of the seat should rise. It is a three position switch. Hope this helps.
Make sure you are not toggling the switch. Try pulling straight up on the switch from the center of the switch. It is a three position switch. Hope this helps.
1 - 5 of 5 Posts
