1 - 20 of 67 Posts
I'd imagine some kind of resistor to fit the cable block would be required, pretty sure someone will be working on it, however, i couldn't imagine not wearing the belt under any situation
There is nothing more annoying then simply driving my truck around property up north and having to hear that damn chime every 5sec. I do wear my seatbelt when I'm driving but I have always hated the reminder chine because it's inconvenient and very annoying when you are going in and out of the truck driving around property doing work.
While you are driving around on your property you can maybe buckle up the seat belt without you being in the seat. This way you will be sitting with the seat belt behind you. It should think you are buckled in as long as there are no other high tech ways of the truck knowing that you are trying to trick it. Lol
Was sitting in my rebel...just tried this 3 timer...didn't work for me
I'm still on mission to figure this out....ticks me off when I wana work on her and listen to the radio
G
Why cant you just get an extra clip and click it in the mechanisim, how is it going to know it is real. and then just use the belt when driving?
Could the Module, just be removed or covered so it isn't as loud?
I've searched and tried to find it and cant
@johnj already brought this up. On another note why spend money on it when you should be able to deactivate it or remove it?
G
Go to Junk Yard find a 2015 Ram truck, and cut the seat belt clip out of the truck, problem solved.
Also interested in this. I've got a guy who works with me that gets in my truck and refuses to wear his seatbelt for the 15 min of driving to the job site. I want to kill myself everyday !
One...he wouldn't ever be riding with me without wearing it...I've stopped my truck and pulled over until my own father put his on and he's 100 lbs and 6 inches bigger than me...
Reactions: ARALPH30
1 - 20 of 67 Posts
