Does anyone know the stock offset for the 2016 rebel? I want to get some wheels and would like a more aggressive stance. I was told that a -12 offset would get me just outside of the wheel well. Any thoughts? Thanks.
Thank you!Does anyone know the stock offset for the 2016 rebel? I want to get some wheels and would like a more aggressive stance. I was told that a -12 offset would get me just outside of the wheel well. Any thoughts? Thanks.
Any idea what would be a good offset to get me just a couple inches outside of the wheelwell?Thank you!
You would want to go negative is what I've been told.you would want less backspace to stick out further right?
The wheels I'm looking at have a -12 offset.You would want to go negative is what I've been told.
this guy is smartMoving from +18mm to -12mm is 30mm difference.
Divide 30mm by 25.4 = 1.2 inches from where the tires sit now.
Or he actually knows how to do simple math..God forbid anyone know how to do that anymorethis guy is smart
Yep, depending on whether the new wheels are setup for ball or tapered nuts. And you should keep a set of spare original nuts for one wheel in the truck. If you ever have to put your spare on, it will need the factory nuts. I haven't checked mine yet but I assume they're tapered (acorn)? Don't really need to worry about it unless you trade the wheels out.Just know in most cases you'll need new lug nuts...some people don't realize that
