What PSI in the front and rear tires are people using for regular everyday driving?
Help me out- what is the advantage of having different tire pressures between the front and rear tires?I have filled mine 55/45 a day after I got the truck as they had them at all different numbers & nitro fill.
I hear nitro gives better MPG, meh! I just equalized them with regular air.
Mine fluctuates 51-55/43-45
The rear tires (generally) have more stress on them in 2wd therefore having a higher pressure can somewhat prevent premature ware. Also a it can help with heavy loads as well as towing.Help me out- what is the advantage of having different tire pressures between the front and rear tires?
I personally don't know. I follow the printed pressure on the door.Help me out- what is the advantage of having different tire pressures between the front and rear tires?
Not at all... rule of thumb is every 6k. I think our trucks are 8k average between oil changes so every oil change is not excessiveEvery oil change...in that a bit excessive?
i do it at the dealer with every oil change.Do you guys get them done at the shop when the oil is being changed or do you have the facilities to do them yourself? I personally don't have the facilities to do it myself, so I do them once a year, usually in the fall. I'm interested to see how they perform in the snow since I've never owned a set of tires such as these.
K thanksi do it at the dealer with every oil change.
