I run my 35x12.5x20's at 53 cold. They warm up to about 57 to 58 psi. If your running 60 psi cold then I would drop them down a little.
Just my opinion.
Bill
Bill,
I just pulled these off the Toyo web site.
The first line is our stock tire, the 285/70r17. Recommended pressure is 55psi, and from the load table it shows Ram is expecting a load of 2900 lbs.
2nd line is for the 315/70r17 (about 34.5x12.5). Toyo recommends 45psi for that tire at the same load.
If you switch to a 20" wheel, it changes again a bit (3rd line). The load rating of 2900 falls between 45psi and 50psi, probably 47psi. (The 315/60r20 is very close to the 12.5x35r20.)
Then I pulled the flotation numbers for 35x12.5 on both 17" and 20" wheels. Here they are. Note that they're slighly different from the numbers above. Toyo recommendations for the same 2900lb load looks to be 48psi for the 17" and 45psi for the 20".
You can see that moving from a 17" wheel to a 20" wheel, the tire change increases load by a fair amount at 60 psi, about 400 lbs per tire, 1600 lbs for the whole truck. Not sure how it will wear compared to the recommended load / pressure range.
