This morning I used the remote start. I got in and drove off. The radio display was as if the screen off button was pressed. The air was on and I was able to adjust using the knob. Radio was working just the display wasn't. This happened to me a few weeks ago I turned off and on the truck and it worked just fine after that. This morning when it happened, I turned it off but the truck would not turn back on. The ignition would come up and it seemed every error came up on the instrument cluster (service air suspension, service electronic brake system, etc). The cluster said to press the clutch and push to start but this wouldn't work. I wasn't able to put the truck in neutral. At one point it said fob not detected and the red security light came on. The fob would still unlock and lock the doors. The remote start didn't work anymore. I called roadside and they towed it to the dealership. The dealership didn't have an update this afternoon. It has 10,000 miles on it. Has anyone had this issue or know what the problem could be?
