Would that be in the normal mode. Of off-road mode. I think that's where it's gonna get tricky with the 3 driving modes.Think its 1.5" but may be wrong.
Okay cool thank youI believe I read 1.5" with 35" tires in off road with no rub
Question for you. I know huh centric should be used but have any particular brand you'd recommend?
Are you getting any rubbing in Eco or normal mode?
What mode where u getting rubbing in tho. And is that the stock tires size ?The spacers are from Direct Auto Import in Canada. With my tires (315/70/17) I had major rubbing on the front wheel wells. I did a bunch of trimming and used tie wraps to pull them back. So far so good since the tie wraps. rubbing was worse when backing up and if there was a slope.
I was rubbing in all modes except offroad. These are not stock sized tires, they are very close to 35".What mode where u getting rubbing in tho. And is that the stock tires size ?
