Great info. Thanks! In that case I'll take it as is with whatever is geared towards heavier off-road.
No problem!
Granted, I have a Sport right now and have never noticed any issues with "slippage" or any sort of delay in the transfer case. I'll use 4 Auto if I'm driving highway in winter weather, 4 Lock for lower speed driving in winter weather, and I think I used 4 Low once to hook up to a fully loaded dump trailer that was at the bottom of a grassy hill in my brother's yard so I didn't chew up all his grass spinning tires haha. I have never noticed one single issue with the 4WD with the electronic clutches.
The issues I've seen guys mentioning are what I'd consider rare and/or extreme conditions. They dug themselves into deep mud and overheated the transfer case by hammering the throttle and trying to spin their way out. They were backing a huge boat up their steep grade gravel driveway and said that the hesitation in the transfer case allowed some rear wheel spin which made the task a lot more difficult than it should have been.
I also have a buddy who took a Power Wagon through a trail in over a foot of frozen over snow and snapped his axel in the process, so like I said, rare and/or extreme circumstances seem to coincide with issues with the 44-44.
However, if you know not to drive around in 4WD all the time on dry pavement, then the 44-45 in the Rebel is fantastic haha. The 44-45 locks front and rear when engaged, but leaves front open from side to side, and usually there's limited slip in the rear for side to side. This allows you to do on the fly shifting in and out of 4 Lock and allows more drivability instead of having the truck buck on you as you turn and the front is completely locked haha.
Sent from my Pixel XL using Tapatalk
