Really really want these. I'm just worried about the increased bearing wear and also how hard it'll be to do myself as a first timer. But man would they look sweet seeing as how I have the upgraded fender flares.
Drums? Lol. Sorry had toGet spacers.
Take off wheel.
Notice the little retainers on the rotors, remove those, put some locktight on, bolt on adapter
Drums? Where? 4 wheel disc on rebel.Drums? Lol. Sorry had to
Ha. The picture didn't open up all the wayDrums? Where? 4 wheel disc on rebel.
Is their a problem if the retainers are not remove?Get spacers.
Take off wheel.
Yes there is a significant problem if you do not. The adapter will not sit flush so wheel will wobble and you will die.Is their a problem if the retainers are not remove?
I have a 2017 with 2 inch spacers. I trimmed a little of the plastic behind the tires and it only rubs very minimal at full turn.Just installed 2” spacers on my 2019 with stock rims and tires. I have a little bit of rub on the the small splash hairs down low. What have y’all done to fix, remove or trim?
View attachment 30063 View attachment 30064
how bad was the rubbing? I was thinking to do the same putting 2 inches Wheel Spacer aftermarket rims but using the same tire duratracJust installed 2” spacers on my 2019 with stock rims and tires. I have a little bit of rub on the the small splash hairs down low. What have y’all done to fix, remove or trim?
Stance looks good! Looking to do something similar but would like to avoid trimming lugs. Do you think 1.5” would clear or would need to go bigger?I put on 1 and 1/4 inch spacers on the front and back To give a more subtle look. I had to trim a little of the bolts to make it fit. Wishing I would’ve done inch and a half just to give it that little extra Aggressive look.
Hey, guys, I just run the BONOSS forged lightweight plus wheel spacers for my car, no problem with it. You can click the link to the website, Then consider whether it is worth the purchase.Has anyone put on 2inch wheel spacers yet? If so any problems
