1 - 20 of 24 Posts
Got a new set of wheels; Vision- Valor, and really like them. I will run these wheels in the summer. Got these from Discount Tire. I wanted to maintain the same balance of polished vs black as the OEM rims. I will put the snow tires on the OEM rims.
no picture and we start calling you QC number 2.
G
17x8.5 FUEL OCTANE D509 Wheels Black w/ Nitto Trail Grappler MT 35x12.50R17 Tires
Tires and rims set from rimzone.com
$2,159.99
G
You googled wrong. Stock rims are 17x8, 5x137.9mm (5x140), offset +18mm. Don't really know what the heck you did google.
Yes, those tires would fit, although a wider rim like a 17x9 might be preferable.
Oh I got that off carid.com
Thank you for the recommendation
np - but you might want to check clearance at the wheel. might need a different offset. or if you are considering wheel spacers you might just want a different offset instead of spacers.
G
I really don't want to have to change anything major, I would just like to most likely get a set of cool looking rims and tires that might be a bit bigger, and keep the original tires and rims to drive on in the winter months.
1 - 20 of 24 Posts
