1 - 11 of 11 Posts
I remember seeing that someone had mounted an after market bumper (not Evil Manufacturing or ADD) on their 2019+ Rebel, and now I can't find it anywhere. I've searched here on this forum, over at 5th gen and even the Rebel Owner's FB page. The guy had posted pictures showing the gap that is left when you mount it and at the time I didn't like it. Now I'm getting impatient and have this idea of using lightbars to cover the gap that is created. If anyone has the link or has done it themselves, please share!
Thats great news! That should fit mine then, Did you run into any issues with the install? When I called them they said it wouldn't fit our rebels. Completely random follow up question do your fog lights come one like the OEM did while making turns etc?
yes sir they work just like oem i got some plugs that fit the oem harness and worked like a charm
as for mounting i basically just got a new piece that attaches to the frame and made the holes 1.75 of a inch higher to clear the gap… rebels have a smaller plastic trim under the lights frame i had to make new holes which was easy. just drill and it looks oem no one would even notice if bumper was off
Do you have a drawing/measurements/pictures of the brackets you made?
1 - 11 of 11 Posts
