I may as well start one of these. My truck is a Bright White 4X4 with RAM boxes and cargo management system. Spray on bed liner came as an added option. I thought I was going to have a CD player (I'm 63 - I have a lot of CDs) in the truck, but apparently they are considered obsolete by most manufacturers nowadays. So my first mod was to go to Prestige Audio on Causeway Blvd. in Metairie, LA for an aftermarket CD player and to have them install some rocks lights and lights for the bed of the truck, also aftermarket. Lastly, my truck did not have the factory light for the inside of the bed, so I picked up a set of those from Mopar, along with the wiring, and had those installed as well.
The CD was placed into the well between the front seats and neatly wired to plug into one of the jacks in the dash. And I have the premium sound system, so it sounds great with all of those Harmon-Kardon speakers. The aftermarket bed lights are situated around the upper rim of the bed and are quite bright. The rock lights (4) are bright, but I should have been explicit that I wanted them under the truck. Prestige installed them in the wheel wells, so my tires are now back lit. Different I guess. Lastly, the Mopar lights in the bed are all wired, but I have to go back to a Dodge dealer to have them enter a code to make them work. It was explained to me as "the truck doesn't know they're there." Prestige added two neat push buttons for the rock lights and upper bed lights. The lower Mopar bed lights have a switch on the light.
I did not have step rails to get in and out of the truck. So I purchased a set of Ionic rails, solid black, which I installed yesterday. They are completely bolt on and very easy to install, although it took me about 2.5 hours. I can't roll around under the truck like when I was younger. They look pretty good! I may change them out later for some rock sliders, but for now, the Ionic rails will do the job.
I got a bonus for Christmas, so I thought about how I'd like to spend it (of course). I made a sizeable donation to the local food bank, Second Harvest, since so many people are out of work due to COVID. New Orleans is generally not an affluent area anyway, so there is always a need at Second Harvest, which I support monthly. With COVID effecting the entire country, a donation to your local food bank would be a blessing to many of your neighbors.
I want to lift and level my truck. My first choice was to get the 6" Rough Country coilover kit. That kit requires new wheels from the 18" OE wheels (a 20" minimum). The more I thought about it, I became concerned that such a radical lift might put undue strain on the upper control arms (UCA), thereby reducing articulation and overstressing the UCA.
When I first joined the Forum and was looking around at other builds on the site, I quickly found Desert Dawg's, which I like quite a bit! Dawg added the Fabtech Dirt Logic 3" coilover lift kit, which includes new steel UPAs. So that was my decision. I purchased the kit yesterday from 4 Wheel Parts (out of stock). I chose the coilovers with the reservoir. This kit will also require a change of wheels from the OE. The Fabtech will allow me to stay with 18s or to move up to a bigger wheel at 20". While I haven't purchased them yet, I am pretty well set on Black Rhino Sprocket wheels. They will give me enough offset and backspace to accommodate the Fabtech lift and I think they look great. If I go with the 18s, I can keep my factory Goodyears until they need replacing. Nitto Ridge Grapplers maybe? That's a long way off though.
Well, that's it for now. I will try to get some photos to post into this thread, but as I tell people, I'm an analog man living in a digital world. Hopefully, I can give others on the Forum some ideas of what works and what doesn't.
