Hiya all,
I'm going to post as many pics as time will allow. I purchased a Smittybuilt winch to add to my rebel. I also got some accessories, snatch block, 20' double looped 20ton strap, two 1" cleats, a Smittybuilt base frame that will have to be modified and, a few other misc. parts.
The winch itself is rated at 9500 lbs. it has a clutch changing lever on top, but due to the mounting location I will be only using the remote to pay out the hook and wire.
I have already mounted the fairlead to be able to mark the hole to be cut thru the skid plate.
Each pic or batch I will give a brief description so if you don't understand something just ask.
Chris
Chris
